i have a problem, and i hope you can help me.
What do i want to do:
I do have a check, which shall be checking the whole day, but only sends out notifications between 23:00 and 23:30. This check is always in critical state (i know this is dumb, but this is out of my hands).
Service:
apply Service "EC printout times check" {
check_command = "ec_printout_times_check"
check_interval = 15m
retry_interval = 1m
groups=["single-mail-evening"]
assign where "DB" in host.groups
Timeperiod
object TimePeriod "evening" {
display_name = "Icinga 2 evening period"
ranges = {
"monday" = "23:00-23:30"
"tuesday" = "23:00-23:30"
"wednesday" = "23:00-23:30"
"thursday" = "23:00-23:30"
"friday" = "23:00-23:30"
"saturday" = "23:00-23:30"
"sunday" = "23:00-23:30"
Notification:
apply Notification "single-mail-evening-icingaadmin" to Service {
import "mail-service-notification"
user_groups = ["icingaadmins"]
vars.notification_from = "<mailaddress>"
interval = 15m
period="evening"
assign where "single-mail-evening" in service.groups
My problem is, that the first check, which will be executed during the time of the “evening” period, will not trigger a (re)notification sending.
Example:
Check runs an 23:05 no notification generated
Check runs again at 23:20, i will get a notification.
I also checked icinga debug log, and there is no entry about a notification (excerpt from a test 1 hour later)
[2021-06-08 00:12:06 +0000] debug/CheckerComponent: Scheduling info for checkable 'PROD - DB!EC printout times check' (2021-06-08 00:12:06 +0000): Object 'PROD - DB!EC printout times check', Next Check: 2021-06-08 00:12:06 +0000(1.62311e+09).
[2021-06-08 00:12:06 +0000] debug/CheckerComponent: Executing check for 'PROD - DB!EC printout times check'
[2021-06-08 00:12:06 +0000] debug/Checkable: Update checkable 'PROD - DB!EC printout times check' with check interval '900' from last check time at 2021-06-07 23:57:50 +0000 (1.62311e+09) to next check time at 2021-06-08 00:26:22 +0000 (1.62311e+09).
[2021-06-08 00:12:06 +0000] notice/ApiListener: Relaying 'event::SetLastCheckStarted' message
[2021-06-08 00:12:06 +0000] notice/ApiListener: Relaying 'event::SetNextCheck' message
[2021-06-08 00:12:06 +0000] notice/Process: Running command '/usr/lib//nagios/plugins/ec_printout_times_check.rb' '--critical_value' '60' '--dbtype' 'anon' '--hostname' 'anon' '--password' 'anon' '--username' 'anon': PID 4511
[2021-06-08 00:12:06 +0000] debug/CheckerComponent: Check finished for object 'PROD - DB!EC printout times check'
[2021-06-08 00:12:06 +0000] notice/CheckerComponent: Pending checkables: 0; Idle checkables: 155; Checks/s: 0.716667
[2021-06-08 00:12:06 +0000] notice/Process: PID 4511 ('/usr/lib//nagios/plugins/ec_printout_times_check.rb' '--critical_value' '60' '--dbtype' 'anon' '--hostname' 'anon' '--password' 'anon' '--username' 'anon') terminated with exit code 2
[2021-06-08 00:12:06 +0000] debug/Checkable: Update checkable 'PROD - DB!EC printout times check' with check interval '900' from last check time at 2021-06-08 00:12:06 +0000 (1.62311e+09) to next check time at 2021-06-08 00:26:22 +0000 (1.62311e+09).
[2021-06-08 00:12:06 +0000] notice/ApiListener: Relaying 'event::CheckResult' message
Do i have some error in my configuration?
Thanks in advance for your help
