How can i remove System entry from left menu ?
currently there is no permission for that, but you can open a github feature request in icingaweb2 and hope that others find this permission usefull.
but you wouldn’t directly benefit from that since your icingaweb2 version is old.
what’s your current icingaweb2 version?
Is there a PHP file that can help me remove entries like this?
/etc/icingaweb2/enabledModules/monitoring/configuration.php
By the way, my IcingaWeb version is 2.8.2. Thanks!
not a good idea but here you go:
https://github.com/Icinga/icingaweb2/blob/v2.8.2/library/Icinga/Web/Menu.php
