Hello Icinga community,
At my job our Icinga setup has two masters and two satellites. Lately we have been unable to receive service checks from Satellite 1 because the endpoint is not connected to Master 1 and Master 2, as shown in the screenshot below.
I’ve tried 2 different configurations: 1) Masters initiate connection to Satellite 1 2) Satellite 1 initiates connection to Masters. With both configurations, Satellite 1 has a connection with the Masters for a day or two before it fails again. All certificates for these servers are valid and inbound connections on port 5665 are allowed on all servers. I’ve consulted the troubleshooting documentation, but nothing in there has resolved the issue so far.
Below are the relevant configuration details from the zones.conf files on all three servers (with domains and IPs obfuscated for security).
zones.conf file for Master 1 and Master 2 are the same
object Endpoint "icinga2master1.domain.org" {
host = "xx.xx.xx.xx"
port = "5665"
object Endpoint "icinga2master2.domain.org" {
port = "5665"
object Endpoint "icinga2sat1.domain.org" {
port = "5665"
zones.conf file on Satellite 1:
object Endpoint "icinga2master2.healthnet.phidc.org" {
object Endpoint "icinga2sat1.uhtasi.org" {
Below is Satellite 1’s host definition (hosts.conf) from Master 1.
object Host "icinga2sat1.domain.org" {
import "generic-host"
zone = "master"
address = "xx.xx.xx.xx"
vars.linux = true
vars.icinga = true
vars.client_endpoint = "icinga2sat1.domain.org"
groups = [ "ApplicationServers"]
Logs (/var/log/icinga2/icinga2.log) on both Masters show the following:
[2022-07-19 09:52:57 -1000] information/ApiListener: Reconnecting to endpoint 'icinga2sat1.domain.org' via host 'xx.xx.xx.xx' and port '5665'
[2022-07-19 09:52:57 -1000] critical/ApiListener: Cannot connect to host 'xx.xx.xx.xx' on port '5665': Connection refused
Features enabled on Master 1:
api checker command debuglog ido-mysql influxdb mainlog notification
Features enabled on Master 2
api checker command ido-mysql mainlog notification
Features enabled on Satellite 1:
api checker debuglog gelf ido-mysql influxdb mainlog
- Version used: 2.13.2
- Operating System and version: CentOS 7
- Icinga Web 2 version: 2.9.5
- Config validation: running “icinga2 daemon -C” on all servers shows configurations are valid
Any insight is appreciated, thanks!
