I have a problem with an agent installed on Linux.
To install the agent I followed the documentation: Working with Agents and Config Zones. These are the steps I have done:
Icinga Agent template
Icinga Director > Hosts > Host Templates > Add
Check command: load
Icinga Agent and zone settings
- Icinga2 Agent: YES
- Establish connection: YES
- Accepts config: YES
zones.d/director-global/host_templates.conf
template Host "Icinga Agent" {
check_command = "load"
Host
Icinga Director > Hosts > Host > Add
Hostname: myClient
Imports: Icinga Agent
Host address: 192.168.2.128
zones.d/icinga2-master/hosts.conf
object Host "myClient" {
import "Icinga Agent"
address = "192.168.2.128"
zones.d/icinga2-master/agent_endpoints.conf
object Endpoint "myClient" {
host = "192.168.2.128"
log_duration = 0s
zones.d/icinga2-master/agent_zones.conf
object Zone "myClient" {
parent = "icinga2-master"
endpoints = [ "myClient" ]
I installed the agent on myClient with “icinga2-agent-kickstart.bash”.
Everything looks fine.
If I go to: Overview > hosts
myClient is UP
Plugin Output: OK - load average: 0.00, 0.00, 0.00
Agent-based services
Icinga Director > Services > Service Templates > Add
Run on agent: Yes
template Service "Agent-based services" {
command_endpoint = host_name
Single Services
Icinga Director > Services > Single Services > Add
Name: Agent - Check Disk
Imports: Agent-based services
Host: Icinga Agent
Check command: disk
zones.d/director-global/service_apply.conf
apply Service "Agent - Check Disk" {
import "Agent-based services"
check_command = "disk"
assign where "Icinga Agent" in host.templates
If I go to: Overview > Services
Agent - Check Disk on myClient
Remote Icinga instance ‘myClient’ is not connected to 'icinga’
On /var/log/icinga2/icinga2.log I found these notes
[2020-04-28 16:11:08 +0000] information/ApiListener: Reconnecting to endpoint 'myClient' via host '192.168.2.128' and port '5665'
[2020-04-28 16:13:19 +0000] critical/TcpSocket: Invalid socket: Connection timed out
[2020-04-28 16:13:19 +0000] critical/ApiListener: Cannot connect to host '192.168.2.128' on port '5665'
[2020-04-28 16:13:19 +0000] information/ApiListener: Finished reconnecting to endpoint 'myClient' via host '192.168.2.128' and port '5665'
Can you please tell me how to solve this issue?
Thank you very much!
