Remote Icinga instance is not connected to master
I am actively using Icinga 2 on a master+client distributed configuration, with a configuration managed by a self-made Ansible role, and things works for months.
Certificates are signed by the master with icinga2 the pki sign-csr command.
Things works when the master can connect to the client on the TCP port 5665, but today I realized that the satellite is not connected to the master if the master cannot connect to the client but viceversa (for example when the satellite is in private natted network):
What I find strange is that I don’t see any relevant error on the client, so it seems that it even don’t try to connect to the master, and for this reason I am thinking about a miss configuration problem.
These are the only logs I see on the client, so it seems to be completely idle:
[2021-06-06 12:16:47 +0200] information/ApiListener: Started new listener on '[0.0.0.0]:5665'
[2021-06-06 12:16:47 +0200] information/CheckerComponent: 'checker' started.
[2021-06-06 12:16:47 +0200] information/ConfigItem: Activated all objects.
[2021-06-06 12:16:56 +0200] information/WorkQueue: #5 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-06-06 12:16:56 +0200] information/WorkQueue: #6 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-06-06 12:21:47 +0200] information/ConfigObject: Dumping program state to file '/var/lib/icinga2/icinga2.state'
[2021-06-06 12:22:06 +0200] information/WorkQueue: #6 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-06-06 12:22:06 +0200] information/WorkQueue: #5 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-06-06 12:26:47 +0200] information/ConfigObject: Dumping program state to file '/var/lib/icinga2/icinga2.state'
[2021-06-06 12:27:16 +0200] information/WorkQueue: #6 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-06-06 12:27:16 +0200] information/WorkQueue: #5 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
This is the /etc/icinga2/zones.conf file on the client:
 * Generated by Ansible
object Endpoint "monitoring.domain.com" {
object Zone "monitoring.domain.com" {
        endpoints = [ "monitoring.domain.com" ]
object Endpoint "dc1.ad.domain.com" {
object Zone "dc1.ad.domain.com" {
        endpoints = [ "dc1.ad.domain.com" ]
        parent = "monitoring.domain.com"
        global = true
        global = true
Could you help me to understand where I’m wrong, please?
Thank you very much!
Bye
I solved my problem!
I enabled the debug log with icinga2 feature enable debuglog and i found this debug log:
[2021-06-06 12:47:01 +0200] debug/ApiListener: Not connecting to Endpoint 'monitoring.domain.com' because the host/port attributes are missing.
So I added host and port attributed on the endpoint object:
        host = "monitoring.domain.com"
        port = 5665
Restarted Icinga2 and now the client is correctly connecting to the master!
Thank you!
Oh my God we had exactly the same problem here! Thank you so much for posting that solution! :slight_smile:
But i cannot understand why the host is deactivate by commenting it out // ?!
We use the kickstart linux script.
