root@monitoring:/home/user# icinga2 ca list
Fingerprint | Timestamp | Signed | Subject
I already read alot about the CA but as you can see there is no ca to list in my monitoring.
The monitored Server is a Windows Server 2022 Datacenter.
My Icinga2 Installation
root@monitoring:/home/user# icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite icingadb influxdb2 livestatus opentsdb statusdata syslog
Enabled features: api checker command ido-mysql influxdb mainlog notification perfdata
root@monitoring:/home/user# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.2-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 11 (bullseye)
Kernel: Linux
Kernel version: 5.10.0-10-amd64
Architecture: x86_64
Build information:
Compiler: GNU 8.3.0
Build host: runner-hh8q3bz2-project-298-concurrent-0
OpenSSL version: OpenSSL 1.1.1k 25 Mar 2021
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
OK What else I have is the icinga2 daemon -C command… It’s a loooong list:
[2021-12-21 10:16:47 +0100] information/cli: Icinga application loader (version: r2.13.2-1)
[2021-12-21 10:16:47 +0100] information/cli: Loading configuration file(s).
[2021-12-21 10:16:47 +0100] information/ConfigItem: Committing config item(s).
[2021-12-21 10:16:47 +0100] information/ApiListener: My API identity: monitoring
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'SELinux Mode' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4824:1-4824:28) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Swap Usage' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4832:1-4832:26) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - auditd.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4840:1-4840:45) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - sshd.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4849:1-4849:43) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - systemd-journald.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4858:1-4858:55) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Units Failed' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4868:1-4868:36) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Top3 Processes Which Caused The Most I/O' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4876:1-4876:56) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Uptime' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4884:1-4884:22) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Users' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4892:1-4892:21) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Database Stats' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4906:1-4906:39) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Java Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4914:1-4914:36) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Channel Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4922:1-4922:39) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4930:1-4930:31) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Backup Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4938:1-4938:38) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Account Stats' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4946:1-4946:38) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Starface Peer Stats' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4954:1-4954:35) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'About me' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4968:1-4968:24) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'CPU Usage' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4976:1-4976:25) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Disk Usage' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4984:1-4984:26) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'DNS' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 4992:1-4992:19) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'File Descriptors' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5000:1-5000:32) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'File Ownership' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5008:1-5008:30) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'File Size - /var/log/messages' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5017:1-5017:45) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'FS inodes' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5026:1-5026:25) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'FS RO' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5034:1-5034:21) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Getent' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5042:1-5042:22) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Icinga' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5050:1-5050:22) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Kernel Ring Buffer (dmesg)' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5058:1-5058:42) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Load' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5066:1-5066:20) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Memory Usage' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5074:1-5074:28) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Network Connections' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5082:1-5082:35) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Procs' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5090:1-5090:21) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Swap Usage' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5098:1-5098:26) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - cron.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5106:1-5106:43) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - rsyslog.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5115:1-5115:46) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - ssh.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5124:1-5124:42) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - systemd-journald.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5133:1-5133:55) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Units Failed' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5142:1-5142:36) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - network.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5150:1-5150:46) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Apache Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5165:1-5165:29) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - apache2.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5173:1-5173:46) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - snmpd.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5191:1-5191:44) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - notify-and-schedule.timer' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5208:1-5208:56) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Systemd Unit - notify-and-schedule.service' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5218:1-5218:58) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Jitsi Videobridge Stats' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5236:1-5236:39) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'Jitsi Videobridge Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5244:1-5244:40) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'NodeBB Stats' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5258:1-5258:28) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'NodeBB Status' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5266:1-5266:29) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] warning/ApplyRule: Apply rule 'NodeBB Version' (in /var/lib/icinga2/api/packages/director/05850b4d-a07a-4e2a-ba2e-f5672ab5f8e6/zones.d/director-global/servicesets.conf: 5274:1-5274:30) for type 'Service' does not match anywhere!
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 33 Notifications.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 9 NotificationCommands.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 43 HostGroups.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 350 Hosts.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 Downtime.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 2 Comments.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 7 Zones.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 5 Endpoints.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 InfluxdbWriter.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 619 CheckCommands.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 UserGroup.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 User.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 13 TimePeriods.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 7 ServiceGroups.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 3683 Services.
[2021-12-21 10:16:49 +0100] information/ConfigItem: Instantiated 1 PerfdataWriter.
[2021-12-21 10:16:49 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2021-12-21 10:16:49 +0100] information/cli: Finished validating the configuration file(s).
Did you check, that you have the permissions on the windows side to call the checks?
There are some videos on youtoube, e.g. Icinga for Windows v1.6.0 - Preview and Q&A - YouTube
Or search for ‘icinga for windows’ on youtube, maybe you find soemthing useful there.
Regards, Matthias
the IcingaforWindows components are hosted locally on the Monitoring server?
the ca.crt file is published by the monitoring server as well?
Is the network between the master and the agent restricted in some way?
Meaning: Can the agent and the master communicate over tcp/5665?
Is the public ca file and machine certs present on the agent under %ProgramData%\icinga2\var\lib\icinga2\certs?
What do the logs under %ProgramData%\icinga2\var\log\icinga2 say?
