Hello, I want to monitor a linux server, like I do with with all my other linux servers.
Only difference is, that this linux server is in a dmz.
Inbound to dmz everything is allowed, but outbound I only allow port 5665.
The first configuration works with no errors, but all the director shows “Remote Icinga instance ‘Client’ is not connected to ‘Master’”.
I tested telnet to the master port 5665 and it works, I also testet telnet port 5665 to the client, also works.
Is there a second port I need to allow in order to get this working?
Log looks like this:
[2022-09-06 15:21:58 +0200] information/FileLogger: 'main-log' started.
[2022-09-06 15:21:58 +0200] information/ApiListener: 'api' started.
[2022-09-06 15:21:58 +0200] information/ApiListener: Started new listener on '[::]:5665'
[2022-09-06 15:21:58 +0200] information/CheckerComponent: 'checker' started.
[2022-09-06 15:21:58 +0200] information/ApiListener: Reconnecting to endpoint 'Master' via host 'Client' and port '5665'
[2022-09-06 15:21:58 +0200] information/ConfigItem: Activated all objects.
[2022-09-06 15:21:58 +0200] information/ApiListener: New client connection for identity 'Master' to [Client]:5665
[2022-09-06 15:21:58 +0200] information/JsonRpcConnection: Requesting new certificate for this Icinga instance from endpoint 'Master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Sending config updates for endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished sending config file updates for endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Syncing runtime objects to endpoint 'Master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished syncing runtime objects to endpoint 'Master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished sending runtime config updates for endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Sending replay log for endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished sending replay log for endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished syncing endpoint 'Master' in zone 'master'.
[2022-09-06 15:21:58 +0200] information/ApiListener: Finished reconnecting to endpoint 'Master' via host 'Client' and port '5665'
[2022-09-06 15:22:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:38712
[2022-09-06 15:22:08 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:38712 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:22:08 +0200] information/WorkQueue: #6 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2022-09-06 15:22:08 +0200] information/WorkQueue: #7 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2022-09-06 15:22:18 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:36794
[2022-09-06 15:22:18 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:36794 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:22:28 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:57772
[2022-09-06 15:22:28 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:57772 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:22:38 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:58684
[2022-09-06 15:22:38 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:58684 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:22:48 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:53570
[2022-09-06 15:22:48 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:53570 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:22:58 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:46574
[2022-09-06 15:22:58 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:46574 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:45946
[2022-09-06 15:23:08 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:45946 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:18 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:53078
[2022-09-06 15:23:18 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:53078 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:28 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:55664
[2022-09-06 15:23:28 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:55664 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:38 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:51160
[2022-09-06 15:23:38 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:51160 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:48 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:44122
[2022-09-06 15:23:48 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:44122 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:23:58 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:48634
[2022-09-06 15:23:58 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:48634 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:55252
[2022-09-06 15:24:08 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:55252 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:18 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:53544
[2022-09-06 15:24:18 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:53544 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:28 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:44232
[2022-09-06 15:24:28 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:44232 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:38 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:57004
[2022-09-06 15:24:38 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:57004 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:48 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:52538
[2022-09-06 15:24:48 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:52538 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:24:58 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:50176
[2022-09-06 15:24:58 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:50176 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:52768
[2022-09-06 15:25:08 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:52768 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:18 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:46832
[2022-09-06 15:25:18 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:46832 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:28 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:38456
[2022-09-06 15:25:28 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:38456 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:38 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:56592
[2022-09-06 15:25:38 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:56592 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:48 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:51186
[2022-09-06 15:25:48 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:51186 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:25:58 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:53398
[2022-09-06 15:25:58 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:53398 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:43292
[2022-09-06 15:26:08 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:43292 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:18 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:47652
[2022-09-06 15:26:18 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:47652 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:28 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:55438
[2022-09-06 15:26:28 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:55438 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:38 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:49046
[2022-09-06 15:26:38 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:49046 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:48 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:54858
[2022-09-06 15:26:48 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:54858 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:58 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:60876
[2022-09-06 15:26:58 +0200] warning/ApiListener: No data received on new API connection from [::ffff:Client]:60876 for identity 'Master'. Ensure that the remote endpoints are properly configured in a cluster setup.
[2022-09-06 15:26:58 +0200] information/ConfigObject: Dumping program state to file '/var/lib/icinga2/icinga2.state'
[2022-09-06 15:27:08 +0200] information/ApiListener: New client connection for identity 'Master' from [::ffff:Client]:37920
I already reinstalled the icinga agent on the client, this exact configuration works on all other clients, only difference is the dmz.
Thanks for advice.
