Remote Icinga instance 'client' is not connected to 'Icinga server'
Hi there,
I am having issues with joining clients via Icinga Director and getting them to communicate back to the Icinga server… I’m quite new to Icinga and I am learning as I go.
I was wondering if someone could help me out? Maybe point me in the right direction - could I have installed something incorrectly?
Install info
Icinga 2 has been installed on a Ubuntu Server:
Here, I installed the icinga 2 packages using:
I then enabled Icinga 2’s MySQL Feature and then installed Icinga 2’s Web Interface:
After setting up Icinga 2’s web Interface, I then installed Icinga Director from GIT repository:
I then enabled the module.
Thank you!
More Info about my Icinga set up
Icinga 2 version:
Icinga2 feature list:
Icinga2 daemon:
Icinga Web 2 Version and Loaded Modules:
Icinga 2 Conf file:
Icinga 2 zones.conf file
Icinga 2 object list --type Endpoint
Icinga 2 object list --type Zone
Sorry about the spam - just wanted to give as much info as I can!
Hi Mark, thank you for joining!
Maybe it is me watching this on my ipad tonight but the pictures arent great.
Can you pust the config in a code block? You can use markdown formatting for this.
It seems you have gotten quite far in your initial setup!
I am sure you have seen this page ?
A few guesses now are
  • icinga is not running on the agent
  • firewall is blocked
Perhaps you already solved it? Either way happy to help
