Reduce dependency logs
  • icinga2 : 2.14.2-1+debian11
  • icingadb : 1.2.0-1+debian11
When I activate debuglog, I notice that I’m logging Dependencies every second; for example
[2024-07-17 10:52:13 +0200] notice/Dependency: Dependency ‘HOST!DEPENDENCY’ passed: Parent host ‘HOST’ matches state filter.
Not only that’s filling the logs quite quickly, but also that’s just flooding them.
Is there any way to stop/configure this , so logs can be a bit more clean, and also so the Icinga Server can not waste ressources on this ?
disable debug log.
only enable this if you experience problems you actually have to debug.
if you thing that it is an actual bug you can open a issue on github for that.
