Recurring Downtime
Hi !
Is there a way with director to schedule a recurring downtime ?
I have some server that are down for backup in the same hour - every day - for backup
Other servers that are in the public cloud and are turned off during the night.
How can I stop monitoring and notification for these kinds of situations?
P.
I can’t answer this specifically relating to Director, but take a look at Time
Periods at https://icinga.com/docs/icinga2/latest/doc/08-advanced-topics/ and
consider applying those to your notifications.
I’m not certain you can disable the monitoring checks themselves, but you can
certainly disable notifications during times when you know things are not
working or are under unusual load etc.
Regards,
Antony
Hi, in short: yes
Where did you find this in director, is this an added module ?
No, it was added to the Director with v1.7.0
