In director i can specify to create the downtime for all services of the host and the host itself. How can i do that in my recuring downtime? Is there an option for that?
for recurring downtimes (ScheduledDowntimes) you have to configure them for host objects and for the service objects seperatly. Maybe there will be an option in the future (hint: ask for a new feature on github).
I don’t think that this will happen, since the apply rule needs a scope, either to Host or to Service to know about the specific objects and their possible attributes in assign where expressions. When implementing the apply rules, we thought about such generics already, and decided against it. Technically, service apply rules would also need to Host, but since there’s only one route, this is hidden by default.
You can always put attributes into templates for instance, and only import them into apply rules, hiding duplicated parts in there.
Hi!
How can I create a "ScheduledDowntimeTemplate from Director - as you tell above ?
IN the director → Downtime section - Only Downtime are possible. I can’t see any TEMPLATE feature here…
In addiction how can insert\define the ranges in Downtime section of director ?
thx
Since reducing the notification amount increases the attentiveness of the admin, we have to implement recurring downtimes for hosts and their services.
I really would like to use your template, but the director manages the config files and I don’t want to mess this up.
Where is the right place to add manual configs when using the director?
