Hi there,
we run a multiple satellite setup within our infrastructure. Due to network limitations and for security reasons we deployed the master in a DMZ, talking just to one satellite nearby. As we now placed a 2nd satellite on a remote network, we get the behaviour I tried to show you on the graphic.
Behaviour in words:
Initiating checks from SAT1 to SAT2 and its attached infrastructure - the checks are performed and the results are sent to SAT1 and from there to the master
Self-Checks on SAT2 are performed and sent back to SAT1 and the master
Certificate requests from SAT2 and the attached infrastructure are transmitted to the master via SAT1 and get back the way smoothly
Checks initiated by the master are performed on SAT2 and the attached infrastructure, the results are sent to SAT1 and NOT sent to the master - or not processed there
SAT2 cannot communicate with the master directly, all communication needs to be handled by SAT1.
Any help or even ideas what to examin is appreciated. We run out of ideas a time ago already and reinstalled SAT2 already, having the same result.
Thank you
Stay save and healthy
Andreas
