Rearrange Dashlet
Hi is there a way to rearrange the dashlet on the dashboard, I am running icinga2 on a linux box.
Currently I have:
Service Problems
Recently Recovered Services
Host Problems
I would like to move host problems above Recently recovered.
no that’s currently not supported. Though, it’s a well desired feature:
As an example: If you use the unedited default dashboard atm, there will be no /etc/icingaweb2/dashboards folder, as this folder and the .ini files are only created “on demand”, when a user edits their dashboard.
So just add something to your dashboard and then edit the .ini file by hand
Though, be careful with such changes :stuck_out_tongue:
:stuck_out_tongue_closed_eyes:
I know this is a 3 year old thread, but if I’m not mistaking, this still isn’t possible (could only find a roadmap showcasing this https://icinga.com/blog/2020/06/11/current-state-of-development-dashboards/)
Can anyone confirm this is not possible yet?
We’re working on 2.7.3
