Hi Community,
I have setup an running icinga2 version: r2.6.0-1 with a lot of icinga clients in different Subnetworks.
Everything runs fine! But for some Hosts I get from time to time a notification that the Service are unknown with additional Info:
Remote Icinga instance ‘server’ is not connected to ‘icinga master’.
After some minutes the Service are OK.
Any idea?
In the log of the Master I found the following:
[2021-11-24 17:19:23 +0100] information/JsonRpcConnection: No messages for identity 'server' have been received in the last 60 seconds.
[2021-11-24 17:19:23 +0100] warning/JsonRpcConnection: API client disconnected for identity 'server'
[2021-11-24 17:19:23 +0100] warning/ApiListener: Removing API client for endpoint 'server'. 0 API clients left.
[2021-11-24 17:20:16 +0100] information/JsonRpcConnection: Reconnecting to API endpoint 'server' via host 'server' and port '5665'
[2021-11-24 17:20:16 +0100] information/ApiListener: New client connection for identity 'server' to [xxx.xxx.xxx.xxx]:5665
[2021-11-24 17:20:16 +0100] information/ApiListener: Sending config updates for endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Syncing configuration files for global zone 'global-commands' to endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Syncing runtime objects to endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Finished syncing runtime objects to endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Finished sending config updates for endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Sending replay log for endpoint 'server'.
[2021-11-24 17:20:16 +0100] information/ApiListener: Finished sending replay log for endpoint 'server'.
[2021-11-24 17:24:08 +0100] information/JsonRpcConnection: No messages for identity 'server' have been received in the last 60 seconds.
[2021-11-24 17:24:08 +0100] warning/JsonRpcConnection: API client disconnected for identity 'server'
[2021-11-24 17:24:08 +0100] warning/ApiListener: Removing API client for endpoint 'server'. 0 API clients left.
[2021-11-24 17:24:16 +0100] information/JsonRpcConnection: Reconnecting to API endpoint 'server' via host 'server' and port '5665'
[2021-11-24 17:24:16 +0100] information/ApiListener: New client connection for identity 'server' to [xxx.xxx.xxx.xxx]:5665
[2021-11-24 17:24:16 +0100] information/ApiListener: Sending config updates for endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Syncing configuration files for global zone 'global-commands' to endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Syncing runtime objects to endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Finished syncing runtime objects to endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Finished sending config updates for endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Sending replay log for endpoint 'server'.
[2021-11-24 17:24:16 +0100] information/ApiListener: Finished sending replay log for endpoint 'server'.
[2021-11-24 17:28:38 +0100] information/JsonRpcConnection: No messages for identity 'server' have been received in the last 60 seconds.
[2021-11-24 17:28:38 +0100] warning/JsonRpcConnection: API client disconnected for identity 'server'
[2021-11-24 17:28:38 +0100] warning/ApiListener: Removing API client for endpoint 'server'. 0 API clients left.
[2021-11-24 17:29:16 +0100] information/JsonRpcConnection: Reconnecting to API endpoint 'server' via host 'server' and port '5665'
[2021-11-24 17:29:16 +0100] information/ApiListener: New client connection for identity 'server' to [xxx.xxx.xxx.xxx]:5665
[2021-11-24 17:29:16 +0100] information/ApiListener: Sending config updates for endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Syncing configuration files for global zone 'global-commands' to endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Syncing runtime objects to endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Finished syncing runtime objects to endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Finished sending config updates for endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Sending replay log for endpoint 'server'.
[2021-11-24 17:29:16 +0100] information/ApiListener: Finished sending replay log for endpoint 'server'.
