all rabbitmq check plugins i found are based on the management api. The recommended way is using the rabbitmq_prometheus plugin, which exposes metrics in the prometheus format.
Is it possible to read those metrics with something like check_prometheus_metric ? Did not get it to work, but am absolutely new to prometheus…
Thanks for any hint,
Christian
