This issue happened twice on the config master and it wasn’t an active endpoint at the time so far since the deployment of this new clusters. No Icinga2 agents.
/var/log# lscpu | grep On-line
On-line CPU(s) list: 0-7
# free -k
total used free shared buff/cache available
Mem: 16375740 601864 15768096 11920 309112 15773876
Swap: 4194300 91932 4102368
- Version used (
icinga2 --version)
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.15.0-1)
Copyright (c) 2012-2025 Icinga GmbH (https://icinga.com/)
System information:
Platform: Ubuntu
Platform version: 24.04.3 LTS (Noble Numbat)
Kernel: Linux
Kernel version: 6.8.0-78-generic
Architecture: x86_64
Build information:
Compiler: GNU 13.3.0
OpenSSL version: OpenSSL 3.0.13 30 Jan 2024
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Enabled features (
icinga2 feature list)
# icinga2 feature list
Disabled features: checker command compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 journald livestatus notification opentsdb perfdata syslog
Enabled features: api ido-mysql mainlog
- Icinga Web 2 version and modules (System - About)
2.12.5
- Config validation (
icinga2 daemon -C)
# icinga2 daemon -C
[2025-09-05 13:16:18 -0700] information/cli: Icinga application loader (version: r2.15.0-1)
[2025-09-05 13:16:18 -0700] information/cli: Loading configuration file(s).
[2025-09-05 13:16:18 -0700] information/ConfigItem: Committing config item(s).
[2025-09-05 13:16:18 -0700] information/ApiListener: My API identity: x.y.com
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 126526 Notifications.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 7 NotificationCommands.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 1 IcingaApplication.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 57 HostGroups.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 8017 Hosts.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 3 Downtimes.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 1 FileLogger.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 9 Zones.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 14 Endpoints.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 3 ApiUsers.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 1 ApiListener.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 383 CheckCommands.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 133 Users.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 110 UserGroups.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 108 ServiceGroups.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 14 TimePeriods.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 48190 Services.
[2025-09-05 13:16:28 -0700] information/ConfigItem: Instantiated 4 ScheduledDowntimes.
[2025-09-05 13:16:28 -0700] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2025-09-05 13:16:28 -0700] information/cli: Finished validating the configuration file(s).
From kern.log
2025-09-05T12:12:53.613161-07:00 x.y.com kernel: icinga2 invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
2025-09-05T12:12:53.628775-07:00 x.y.com kernel: CPU: 3 PID: 742676 Comm: icinga2 Not tainted 6.8.0-78-generic #78-Ubuntu
2025-09-05T12:12:53.628777-07:00 x.y.com kernel: Hardware name: Red Hat KVM/RHEL, BIOS 1.16.3-2.el9 04/01/2014
2025-09-05T12:12:53.628778-07:00 x.y.com kernel: Call Trace:
2025-09-05T12:12:53.634179-07:00 x.y.com kernel: <TASK>
2025-09-05T12:12:53.635783-07:00 x.y.com kernel: dump_stack_lvl+0x76/0xa0
2025-09-05T12:12:53.635784-07:00 x.y.com kernel: dump_stack+0x10/0x20
2025-09-05T12:12:53.640106-07:00 x.y.com kernel: dump_header+0x49/0x210
2025-09-05T12:12:53.640107-07:00 x.y.com kernel: oom_kill_process+0x118/0x280
2025-09-05T12:12:53.640108-07:00 x.y.com kernel: ? oom_evaluate_task+0x143/0x1e0
2025-09-05T12:12:53.640108-07:00 x.y.com kernel: out_of_memory+0x103/0x350
2025-09-05T12:12:53.640109-07:00 x.y.com kernel: __alloc_pages_may_oom+0x10c/0x1d0
2025-09-05T12:12:53.640110-07:00 x.y.com kernel: __alloc_pages_slowpath.constprop.0+0x420/0x9f0
2025-09-05T12:12:53.640110-07:00 x.y.com kernel: __alloc_pages+0x31f/0x350
2025-09-05T12:12:53.640111-07:00 x.y.com kernel: alloc_pages_mpol+0x91/0x210
2025-09-05T12:12:53.650367-07:00 x.y.com kernel: alloc_pages+0x5b/0xd0
2025-09-05T12:12:53.650369-07:00 x.y.com kernel: folio_alloc+0x15/0x40
2025-09-05T12:12:53.650370-07:00 x.y.com kernel: filemap_alloc_folio+0xf4/0x100
2025-09-05T12:12:53.650370-07:00 x.y.com kernel: __filemap_get_folio+0x195/0x2d0
2025-09-05T12:12:53.650371-07:00 x.y.com kernel: filemap_fault+0x15c/0x8e0
2025-09-05T12:12:53.650371-07:00 x.y.com kernel: __do_fault+0x3a/0x190
2025-09-05T12:12:53.650372-07:00 x.y.com kernel: do_read_fault+0x133/0x200
2025-09-05T12:12:53.650372-07:00 x.y.com kernel: do_fault+0xf0/0x260
2025-09-05T12:12:53.660507-07:00 x.y.com kernel: handle_pte_fault+0x114/0x1d0
2025-09-05T12:12:53.660509-07:00 x.y.com kernel: __handle_mm_fault+0x654/0x800
2025-09-05T12:12:53.660510-07:00 x.y.com kernel: handle_mm_fault+0x18a/0x380
2025-09-05T12:12:53.660510-07:00 x.y.com kernel: do_user_addr_fault+0x169/0x670
2025-09-05T12:12:53.660511-07:00 x.y.com kernel: exc_page_fault+0x83/0x1b0
2025-09-05T12:12:53.660511-07:00 x.y.com kernel: asm_exc_page_fault+0x27/0x30
2025-09-05T12:12:53.660512-07:00 x.y.com kernel: RIP: 0033:0x7146fc223630
2025-09-05T12:12:53.660513-07:00 x.y.com kernel: Code: Unable to access opcode bytes at 0x7146fc223606.
2025-09-05T12:12:53.661857-07:00 x.y.com kernel: RSP: 002b:00007146fa533288 EFLAGS: 00010246
2025-09-05T12:12:53.661859-07:00 x.y.com kernel: RAX: 000071468c029190 RBX: 0000000000000000 RCX: 00007146fba05780
2025-09-05T12:12:53.661859-07:00 x.y.com kernel: RDX: 0000000000000056 RSI: 00007146fc3ecb41 RDI: 0000000000000000
2025-09-05T12:12:53.661860-07:00 x.y.com kernel: RBP: 00007146fa5332b0 R08: 0000000000000000 R09: 0000000000000000
2025-09-05T12:12:53.661861-07:00 x.y.com kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 000071468c029190
2025-09-05T12:12:53.661861-07:00 x.y.com kernel: R13: 00007146fc3ecb41 R14: 0000000000000000 R15: 00005657042427a0
2025-09-05T12:12:53.661862-07:00 x.y.com kernel: </TASK>
2025-09-05T12:12:53.661862-07:00 x.y.com kernel: Mem-Info:
2025-09-05T12:12:53.668219-07:00 x.y.com kernel: active_anon:1592644 inactive_anon:2403968 isolated_anon:0
2025-09-05T12:12:53.668221-07:00 x.y.com kernel: active_file:0 inactive_file:50 isolated_file:0
2025-09-05T12:12:53.668222-07:00 x.y.com kernel: unevictable:6821 dirty:0 writeback:0
2025-09-05T12:12:53.668222-07:00 x.y.com kernel: slab_reclaimable:6913 slab_unreclaimable:24893
2025-09-05T12:12:53.668223-07:00 x.y.com kernel: mapped:4082 shmem:2032 pagetables:11134
2025-09-05T12:12:53.668223-07:00 x.y.com kernel: sec_pagetables:0 bounce:0
2025-09-05T12:12:53.668224-07:00 x.y.com kernel: kernel_misc_reclaimable:0
2025-09-05T12:12:53.668224-07:00 x.y.com kernel: free:34160 free_pcp:0 free_cma:0
Using MySQL IDO (MariaDB 10.11.13) with HA enabled. The secondary master apperared working normal at the time. No files were generated in /var/log/icinga2/crash
Please advise
