hi all is there any way to download graphna graph report or data ?
thanks for the reply , is there any way to get that report it in csv or pdf format ?
Grafana is strictly visual for the most part. Are you using Influx or Graphite as your backend? InfluxDB can export to csv format if you’re comfortable running the queries directly.
