Hi everybody,
I want add custom variables for every host that will be added to the Icingaweb2 Interface.
I want to use these custom host variables to e.g. set threshold values for specific host-checks, that have a default value and can be offset with a configuration file.
Since I am already successfully using the puppet module by voxpopuli and succeeded to implement puppet facts into Icingaweb2, I kinda know that the infrastructure is already there.
I know it is possible to take variables from puppet facts and convert them to variables / properties of nodes in Icinga2, this basically works with either Icinga2 or Icingaweb2 via the director that assigns values.
My problem is now:
How can I add custom variables from hiera files to Icingaweb2 via puppet?
On my puppet server, I have the usual hieradata structure with a hiera.yaml file for every module, a common.yaml file and the hierdata-directory with host specific information.
However I don’t know how to get custom variables into puppetdb, they don’t get implemented from the host-specific yaml files.
I am aware that this issue might leave the scope of this community. Still I hope, that someone can at least point me in the right direction, as I don’t know where to look for the issue anymore.
If there is an easier way to add per host variables via puppet to Icinga in an organized way, I am of course open to suggestions.
Thank you very much.
