i have a new proposal for a feature for icinga director webgui.
sometimes if you configure a host or service you will require to change the template(e.g. add addiotional field) or check sth in the template.
At the moment you need several clicks to switch to the definition of the template
So i think it would be usefull if you can jump from import fields directly to the definition of the items.
BR
Thomas
