I’m having problems installing the Icinga Web 2 update 2.8.3 (from 2.8.2) via yum update.
The dependencies seem not to be correct.
Some packages do have dependencies to 2.9.0 which would be installed instead of 2.8.3 (see output).
OS: CentOS 7.9
Last try: 2021-07-14 09:30h CEST
# yum update icingaweb2-2.8.3
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: centos.mirror.iphh.net
* centos-gluster6: centos.mirror.iphh.net
* centos-sclo-rh: centos.intergenia.de
* centos-sclo-sclo: centos.bio.lmu.de
* epel: epel.besthosting.ua
* extras: centos.intergenia.de
* updates: centos.intergenia.de
Resolving Dependencies
--> Running transaction check
---> Package icingaweb2.noarch 0:2.8.2-1.el7.icinga will be updated
--> Processing Dependency: icingaweb2 = 2.8.2-1.el7.icinga for package: icingaweb2-selinux-2.8.2-1.el7.icinga.noarch
---> Package icingaweb2.noarch 0:2.8.3-1.el7.icinga will be an update
--> Processing Dependency: icingacli = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-HTMLPurifier = 1:2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-dompdf = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-lessphp = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-Parsedown = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-JShrink = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: php-Icinga = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-common = 2.8.3-1.el7.icinga for package: icingaweb2-2.8.3-1.el7.icinga.noarch
---> Package icingacli.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingacli.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-common.noarch 0:2.8.2-1.el7.icinga will be updated
--> Processing Dependency: icingaweb2-common = 2.8.2-1.el7.icinga for package: icingaweb2-vendor-zf1-2.8.2-1.el7.icinga.noarch
---> Package icingaweb2-common.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-selinux.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-selinux.noarch 0:2.9.0-1.el7.icinga will be an update
--> Processing Dependency: icingaweb2 = 2.9.0-1.el7.icinga for package: icingaweb2-selinux-2.9.0-1.el7.icinga.noarch
icinga-stable-release/7/filelists_db | 546 kB 00:00:00
---> Package icingaweb2-vendor-HTMLPurifier.noarch 1:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-HTMLPurifier.noarch 1:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-vendor-JShrink.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-JShrink.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-vendor-Parsedown.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-Parsedown.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-vendor-dompdf.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-dompdf.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package icingaweb2-vendor-lessphp.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-lessphp.noarch 0:2.8.3-1.el7.icinga will be an update
---> Package php-Icinga.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package php-Icinga.noarch 0:2.8.3-1.el7.icinga will be an update
--> Processing Dependency: icingaweb2-vendor-zf1 = 2.8.3-1.el7.icinga for package: php-Icinga-2.8.3-1.el7.icinga.noarch
---> Package icingaweb2.noarch 0:2.9.0-1.el7.icinga will be an update
--> Processing Dependency: icingaweb2-vendor-JShrink = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-HTMLPurifier = 1:2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingacli = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-dompdf = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-lessphp = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: php-Icinga = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-vendor-Parsedown = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icingaweb2-common = 2.9.0-1.el7.icinga for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-php-library >= 0.6.0-1 for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-php-thirdparty >= 0.10.0-1 for package: icingaweb2-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-l10n >= 1.1.0-1 for package: icingaweb2-2.9.0-1.el7.icinga.noarch
---> Package icingaweb2-vendor-zf1.noarch 0:2.8.2-1.el7.icinga will be updated
---> Package icingaweb2-vendor-zf1.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icinga-l10n.noarch 0:1.0.0-1.el7.icinga will be updated
---> Package icinga-l10n.noarch 0:1.1.0-1.el7.icinga will be an update
---> Package icinga-php-library.noarch 0:0.6.0-1.el7.icinga will be installed
--> Processing Dependency: icinga-php-common for package: icinga-php-library-0.6.0-1.el7.icinga.noarch
---> Package icinga-php-thirdparty.noarch 0:0.10.0-1.el7.icinga will be installed
---> Package icingacli.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-common.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-vendor-HTMLPurifier.noarch 1:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-vendor-JShrink.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-vendor-Parsedown.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-vendor-dompdf.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icingaweb2-vendor-lessphp.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package php-Icinga.noarch 0:2.9.0-1.el7.icinga will be an update
---> Package icinga-php-common.noarch 0:1.0.0-1.el7.icinga will be installed
--> Finished Dependency Resolution
Error: Package: php-Icinga-2.8.3-1.el7.icinga.noarch (icinga-stable-release)
Requires: icingaweb2-vendor-zf1 = 2.8.3-1.el7.icinga
Removing: icingaweb2-vendor-zf1-2.8.2-1.el7.icinga.noarch (@icinga-stable-release)
icingaweb2-vendor-zf1 = 2.8.2-1.el7.icinga
Updated By: icingaweb2-vendor-zf1-2.9.0-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.9.0-1.el7.icinga
Available: icingaweb2-vendor-zf1-1.12.20-1.el7.centos.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 1.12.20-1.el7.centos
Available: icingaweb2-vendor-zf1-2.4.2-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.4.2-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.5.0-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.5.0-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.5.1-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.5.1-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.5.2-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.5.2-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.5.3-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.5.3-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.6.0-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.6.0-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.6.1-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.6.1-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.6.2-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.6.2-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.6.3-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.6.3-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.6.4-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.6.4-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.0-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.0-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.1-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.1-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.2-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.2-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.3-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.3-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.4-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.4-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.7.5-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.7.5-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.8.0-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.8.0-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.8.1-1.el7.icinga.noarch (icinga-stable-release)
icingaweb2-vendor-zf1 = 2.8.1-1.el7.icinga
Available: icingaweb2-vendor-zf1-2.8.3-1.el7.icinga.noarch (icinga-stable-release)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Is there something I can do? I guess the package needs to be corrected.
Thanks for the reply.
Still Icinga Web 2.9.0 would be installed …
E. g.:
# yum update icingaweb2-2.8.3 icingaweb2-selinux-2.8.3
---> Package icingaweb2-selinux.noarch 0:2.8.3-1.el7.icinga will be an update
--> Processing Dependency: icingaweb2-common = 2.9.0-1.el7.icinga for package: icingaweb2-vendor-zf1-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: php-Icinga = 2.9.0-1.el7.icinga for package: icingacli-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-php-library >= 0.6.0-1 for package: icingacli-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-php-thirdparty >= 0.10.0-1 for package: icingacli-2.9.0-1.el7.icinga.noarch
--> Processing Dependency: icinga-l10n >= 1.1.0-1 for package: icingacli-2.9.0-1.el7.icinga.noarch
@nilmerg This seems to do the trick!
Thanks a lot for your support!
Regards,
AlexR
# yum update icingaweb2-2.8.3 icingaweb2-selinux-2.8.3 icingaweb2-vendor-zf1-2.8.3
---> Package icingaweb2-vendor-zf1.noarch 0:2.8.3-1.el7.icinga will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
icingaweb2 noarch 2.8.3-1.el7.icinga icinga-stable-release 2.4 M
icingaweb2-selinux noarch 2.8.3-1.el7.icinga icinga-stable-release 17 k
icingaweb2-vendor-zf1 noarch 2.8.3-1.el7.icinga icinga-stable-release 680 k
Updating for dependencies:
icingacli noarch 2.8.3-1.el7.icinga icinga-stable-release 9.5 k
icingaweb2-common noarch 2.8.3-1.el7.icinga icinga-stable-release 167 k
icingaweb2-vendor-HTMLPurifier noarch 1:2.8.3-1.el7.icinga icinga-stable-release 268 k
icingaweb2-vendor-JShrink noarch 2.8.3-1.el7.icinga icinga-stable-release 11 k
icingaweb2-vendor-Parsedown noarch 2.8.3-1.el7.icinga icinga-stable-release 13 k
icingaweb2-vendor-dompdf noarch 2.8.3-1.el7.icinga icinga-stable-release 2.1 M
icingaweb2-vendor-lessphp noarch 2.8.3-1.el7.icinga icinga-stable-release 40 k
php-Icinga noarch 2.8.3-1.el7.icinga icinga-stable-release 309 k
Transaction Summary
Upgrade 3 Packages (+8 Dependent packages)
Total download size: 6.0 M
Is this ok [y/d/N]:
