Have the following icinga packages on my Debian 9 system:
ii icinga-l10n 1.1.0-1.stretch all l10n (short for Localization) provides all translations available for Icinga.
ii icinga-php-common 1.0.0-1.stretch all Icinga PHP Common for Icinga Web 2
ii icinga-php-library 0.7.0-1.stretch all Icinga PHP Library for Icinga Web 2
ii icinga-php-thirdparty 0.10.0-2.stretch all Icinga PHP Thirdparty for Icinga Web 2
ii icinga2 2.13.1-1.stretch amd64 host and network monitoring system
ii icinga2-bin 2.13.1-1.stretch amd64 host and network monitoring system - daemon
ii icinga2-common 2.13.1-1.stretch all host and network monitoring system - common files
ii icinga2-doc 2.13.1-1.stretch all host and network monitoring system - documentation
ii icinga2-ido-mysql 2.13.1-1.stretch amd64 host and network monitoring system - MySQL support
ii icingacli 2.9.4-1.stretch all simple CLI tool for Icingaweb2 and its modules
ii icingaweb2 2.9.4-1.stretch all simple and responsive web interface for Icinga
ii icingaweb2-common 2.9.4-1.stretch all simple and responsive web interface for Icinga - common files
ii icingaweb2-module-doc 2.9.4-1.stretch all simple and responsive web interface for Icinga - documentation module
ii icingaweb2-module-monitoring 2.9.4-1.stretch all simple and responsive web interface for Icinga - monitoring module
ii php-icinga 2.9.4-1.stretch all PHP library to communicate with and use Icinga
Aplication log is full of the following:
16.11. 17:52
ERROR PDOException in /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php:401 with message: SQLSTATE[42000]: Syntax error or access violation: 1142 DELETE command denied to user ‘icinga_user’@‘localhost’ for table ‘icingaweb_rememberme’
#0 /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php(401): PDO->prepare(String)
#1 /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php(489): ipl\Sql\Connection->prepexec(String)
#2 /usr/share/php/Icinga/Web/RememberMe.php(170): ipl\Sql\Connection->delete(String, Array)
#3 /usr/share/icingaweb2/application/controllers/ApplicationStateController.php(70): Icinga\Web\RememberMe::removeExpired()
#4 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(507): Icinga\Controllers\ApplicationStateController->indexAction()
#5 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch(String)
#6 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response))
#7 /usr/share/php/Icinga/Application/Web.php(304): Zend_Controller_Front->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response))
#8 /usr/share/php/Icinga/Application/webrouter.php(107): Icinga\Application\Web->dispatch()
#9 /usr/share/icingaweb2/public/index.php(4): require_once(String)
#10 {main}
How can I fix this error?
