Hello I have installed Icinga recently. I am sorry because I am still learning and probably this problem should be easy for others, but Ihave been weeks to solve it.
I have installed Icinga Director, and I am trying to use modules as check_interfaces. I have implemented it , telling the interface and community to monitor. The problem comes when I implement it. The following error appears:
execvpe(/usr/lib64/nagios/pluginscheck_interfaces) failed: No such file or directory
I have tried to modify the file more /etc/icinga2/constants.conf, just changing this:
ORIGINAL CONTENT:
const PluginDir = “/usr/lib64/nagios/plugins”
MODIFIED CONTENT:
const PluginDir = “/usr/lib64/nagios/plugins/”
When I change it and restart icinga the following error appears:
check_interfaces 1.4
Usage: check_interfaces -h [OPTIONS] -c -r -R -e -f -p -P -t -b -s -x -m -j -J -k -K -u -d -a -A -D -N --timeout sets the SNMP timeout (in ms) --sleep sleep between every SNMP query (in ms) --retries how often to retry before giving up --max-repetitions see
Please if could you tell me what I am doing wrong I would really appreciate that.
