Problems with Icinga Director and self monitoring of master node
Hi all,
i’m a new user of Icinga2 and i’m trying to migrate from Xymon (BigBrother) to Icinga2. In the first step, i set up an Icinga2 Instance with icingaweb2 and icinga-director.
Setup steps:
  • installiing icinga2
  • running icinga2 node wizard
  • installing Icinga Director
  • starting the kickstart wizard
  • installing some other modules
The Webfrontend seems to be okay, i can change settings and deploy them, but if i try to add the master node into icinga and deploy the changes, icinga director returns an error:
[2022-04-05 08:56:57 +0200] information/cli: Icinga application loader (version: 2.13.2-1)
[2022-04-05 08:56:57 +0200] information/cli: Loading configuration file(s).
[2022-04-05 08:56:57 +0200] critical/config: Error: Object 'master.example.com' of type 'Endpoint' re-defined: in [stage]/zones.d/master/agent_endpoints.conf: 1:0-1:48; previous definition: in /etc/icinga2/zones.conf: 6:1-6:49
Location: in [stage]/zones.d/master/agent_endpoints.conf: 1:0-1:48
[stage]/zones.d/master/agent_endpoints.conf(1): object Endpoint "master.example.com" {
[stage]/zones.d/master/agent_endpoints.conf(2):     host = "master.example.com"
[stage]/zones.d/master/agent_endpoints.conf(3):     log_duration = 0s
[2022-04-05 08:56:57 +0200] critical/cli: Config validation failed. Re-run with 'icinga2 daemon -C' after fixing the config.
Output of the icinga2 node wizard
icinga2 node wizard
Please specify if this is an agent/satellite setup ('n' installs a master setup) [Y/n]: n
Starting the Master setup routine...
Please specify the common name (CN) [master.example.com]:
Reconfiguring Icinga...
Checking for existing certificates for common name 'master.example.com'...
Certificates not yet generated. Running 'api setup' now.
Generating master configuration for Icinga 2.
Enabling feature api. Make sure to restart Icinga 2 for these changes to take effect.
Master zone name [master]:
Do you want to specify additional global zones? [y/N]:
Bind Host []:
Bind Port []:
Do you want to disable the inclusion of the conf.d directory [Y/n]:
Disabling the inclusion of the conf.d directory...
Checking if the api-users.conf file exists...
Done.
Content of /etc/icinga2/zones.conf
 * on 2022-04-04 14:05:18 +0200
object Zone "master" {
        endpoints = [ "master.example.com" ]
        global = true
        global = true
I hope, this information are enough. Details of my installation:
Output of icinga --version
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: 2.13.2-1)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
System information:
  Platform: CentOS Linux
  Platform version: 7 (Core)
  Kernel: Linux
  Kernel version: 3.10.0-1160.59.1.el7.x86_64
  Architecture: x86_64
Build information:
  Compiler: GNU 4.8.5
  Build host: runner-hh8q3bz2-project-322-concurrent-0
  OpenSSL version: OpenSSL 1.0.2k-fips  26 Jan 2017
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf icingadb influxdb influxdb2 livestatus opentsdb perfdata statusdata
Enabled features: api checker command graphite ido-mysql mainlog notification syslog
Maybe it’s just a simple configuration error.
Regards,
Stephan
Hi & welcome,
You need to set Icinga Agent to no for that host.
thanks - that solved the issue :slight_smile:
Hiii I have a similar issue: My server node, on which icinga2, icingaweb2 and the database are running, keeps throwing an error due to redefinition, but tells me, the host, not the endpoint object is being redefined.
Switching the agent to no did not solve the issue when deploying my config.
I would like to ask you to open a new topic for your question instead of replying to an old one like this. That way you inrease the chance of people seeing (and replying) to your question and it is a lot less likely to be overlooked. Thank you!
If you think the original post is relevant to the discussion, you can link to it for more context.
Here we go, thank you very much for the suggestion.
