I have an problem with the ha master setup and icingaweb2.
I recently fixed my problem with the config sync between the masters and then always when the seconf master (not the config master) is online, it shows me nothing in icingaweb2.
When i shut down the second master and only the frist is active i can see all normally in icingaweb2.
Before the fix with the config sync both masters worked fine with icingaweb2 and nothing was changed in the config files.
Does anyone know what this could be?
The zones.conf:
* on 2018-01-10 17:39:07 +0100
object Endpoint "icinga02.picturemaxx.net" {
host = "xxxxxxxxxxx"
object Endpoint "pr-be-ic-mas-02" {
host = "xxxxxxxxxxxx"
#object Endpoint "ic-sat-qsc01" {
# host = "xxxxxxxxxxxxx"
# /* host = "xxxxxxxxxxx" */
object Endpoint "ic-sat-qsc01-VM" {
host = "xxxxxxxxxxxxxx"
#object Endpoint "icinga02-sat-off.picturemaxx.net" {
# host = "xxxxxxxxxxxx"
#object Endpoint "icinga02-sat-aws.picturemaxx.net" {
object Endpoint "ic-sat-aws-apne1-01" {
object Endpoint "ic-sat-aws-use1-01" {
object Endpoint "ic-sat-aws-euw1-01" {
object Endpoint "ic-sat-aws-euc1-01" {
object Endpoint "pr-be-ic-sat-off-01" {
object Zone "ic-mas-qsc01" {
endpoints = [ "icinga02.picturemaxx.net", "pr-be-ic-mas-02" ]
object Zone "ic-sat-qsc01" {
endpoints = [ "ic-sat-qsc01-VM" ]
parent = "ic-mas-qsc01"
object Zone "ic-sat-off01" {
endpoints = [ "pr-be-ic-sat-off-01" ]
#object Zone "ic-sat-aws01" {
# endpoints = [ "icinga02-sat-aws.picturemaxx.net" ]
# parent = "ic-mas-qsc01"
object Zone "ic-sat-aws-apne1-01" {
endpoints = [ "ic-sat-aws-apne1-01" ]
object Zone "ic-sat-aws-euw1-01" {
endpoints = [ "ic-sat-aws-euw1-01" ]
object Zone "ic-sat-aws-euc1-01" {
endpoints = [ "ic-sat-aws-euc1-01" ]
object Zone "ic-sat-aws-use1-01" {
endpoints = [ "ic-sat-aws-use1-01" ]
object Zone "global-config" {
global = true
global = true
The api.conf:
* The API listener is used for distributed monitoring setups.
object ApiListener "api" {
accept_config = true
accept_commands = true
ticket_salt = TicketSalt
object ApiUser "client-pki-ticket" {
password = "xxxxxxxxxxxxxxx"
permissions = [ "actions/generate-ticket" ]
object ApiUser "director" {
permissions = [ "*" ]
object ApiUser "dashing" {
password = "xxxxxxxxxxxxxxxx"
permissions = [ "status/query", "objects/query/*" ]
The ido-mysql.conf:
library "db_ido_mysql"
object IdoMysqlConnection "ido-mysql" {
user = "icinga2",
password = "xxxxxxxxxxxx",
host = "10.49.96.196",
database = "icinga2"
cleanup = {
contactnotifications_age = 30d
downtimehistory_age = 48h
servicechecks_age = 96h
statehistory_age = 48h
flappinghistory_age = 48h
The Icingaweb2 command transport config:
[icinga2-api]
transport = "api"
host = "10.49.80.25"
port = "5665"
username = "director"
[icinga2-api-2nd-master]
transport = "api"
host = "10.49.80.250"
port = "5665"
password = "xxxxxxxxxxxxxx"
[icinga2]
transport = "local"
path = "/var/run/icinga2/cmd/icinga2.cmd"
The Icingaweb2 resources config:
[icingaweb_db]
type = "db"
db = "mysql"
#host = "localhost"
port = ""
dbname = "icingaweb2"
username = "icingaweb2"
password = "xxxxxxxxxxxxx"
#charset = ""
charset = "latin1"
persistent = "0"
use_ssl = "0"
[icinga_ido]
type = "db"
db = "mysql"
#host = "localhost"
port = ""
dbname = "icinga2"
username = "icinga2"
password = "xxxxxxxxxxx"
charset = "latin1"
#charset = ""
persistent = "0"
use_ssl = "0"
[ad]
type = "ldap"
hostname = "10.49.88.8"
port = "389"
root_dn = "DC=muc,DC=pm"
bind_dn = "CN=svc_SSO,OU=Agents,OU=PM-MUC,DC=muc,DC=pm"
bind_pw = "xxxxxxxxxxxxxx"
[icingadb]
type = "db"
db = "mysql"
host = "127.0.0.1"
dbname = "icingadb"
username = "icingadb"
password = "icingadb"
use_ssl = "0"
charset = "latin1"
- Version used (
icinga2 --version):
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.7-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 11 (bullseye)
Kernel: Linux
Kernel version: 5.10.0-23-amd64
Architecture: x86_64
Build information:
Compiler: GNU 10.2.1
OpenSSL version: OpenSSL 1.1.1n 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Operating System and version: Debian 11.6
- Enabled features (
icinga2 feature list):
Disabled features: compatlog debuglog elasticsearch gelf icingadb influxdb influxdb2 opentsdb perfdata statusdata syslog
Enabled features: api checker command graphite ido-mysql livestatus mainlog notification
Greetings
dcz01
