I am New to Icinga, after adding the hosts i installed check_snmp_printer plugin from the community to use it as a service: check_snmp_printer :: Icinga Exchange
i got an error which is this:
Plugin Output
Only use one of messages|model|consum|trays|pagecount|firmware options
/usr/lib/nagios/plugins/check_snmp_printer v2.0.1 (monitoring-plugins 2.3.2)
The Monitoring Plugins come with ABSOLUTELY NO WARRANTY. You may redistribute
copies of the plugins under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING.
Check a printer through SNMP.
Usage:
check_snmp_printer -H host [-C snmp_community] [-v snmp_version] [-t timeout]
check_snmp_printer --version
check_snmp_printer --help
Required Arguments:
-H, --host=HOST
The name or address of the host running SNMP.
–messages
Print the messages of the printer
–model
Prints the model of the printer
–pagecount
Prints the number of pages printed
–trays
Checks trays for paper status.
–consum
Checks consumables for status.
–firmware
Checks current firmware revision and date of printer.
- Icinga 2 version : r2.14.2-1
- Operating System and version: ubuntu 23
- Webserver: apache2
PHP versions: 8.1
