When i can try to install this package: icingadb-redis in my machine (Ubuntu Server latest version) I received this message: Unable to locate package icingadb-redis.
Also I tried with apt update but nothing, the problem persist
Hi @Samuele28
I think it’s in the Icinga repository and did you add it?
What’s the output of apt update?
Having the same issue. Here is the output of the apt install icingadb-redis:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package icingadb-redis
Results from apt update:
Hit:6 https://packages.icinga.123/ubuntu icinga-mantic InRelease
Err:7 https://packages.icinga.123/ubuntu icinga-mantic-testing Release
404 Not Found [IP: 185.233.189.126 443]
E: The repository ‘1234://packages.icinga.1234/ubuntu icinga-mantic-testing Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Working on a demo install of Icinga2 for work and this is holding it up now.
there are no packages for 23.10 since it is not officially supported as an icinga server disto
https://packages.icinga.com/ubuntu/pool/main/i/icingadb-redis/
here is the support matrix which indicates to use a LTS distro
just for the record it is there and wasn’t available on feb 2024:
but regardless of that, it is better to use an LTS distro
