Problem with influxdb / satellites / grafana
Thanks to a very kind member here I have now managed to learn how to add and configure satellites and endpoints to my master.
I’ve managed to setup some custom plugins, and the plugins work great - reporting back data that I can view in icing web. I’ve made a ton of progress!
I have set up grafana graphs and influx dB and all checks run from the master display graphs in my web interface (eg, hostalive, SNMP against devices on the same network). However, check that are ran on endpoints are showing as ‘no data points’ available in grafana graphs. I believe this may be because the data from the endpoints isn’t being written to influx dB (hence no data to display).
Can anyone please nudge me in the right direction so that I can try and discover what is wrong?
Thank you,
J
