I installed icinga2, icingadb-redis and icingadb on Debian11.
After installing icingadb i created the database in mariadb and imported the schema:
mariadb
MariaDB [(none)]> CREATE DATABASE icingadb;
MariaDB [(none)]> GRANT ALL ON icingadb.* TO icingadb@localhost IDENTIFIED BY '< password >';
MariaDB [(none)]> FLUSH PRIVILEGES;
MariaDB [(none)]> exit
mariadb icingadb </usr/share/icingadb/schema/mysql/schema.sql
I stored icingadb password in its field inside /etc/icingadb/config.yml, then i restarted the service:
systemctl restart icingadb
But i got this error:
systemctl status icingadb
● icingadb.service - Icinga DB
Loaded: loaded (/lib/systemd/system/icingadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2023-02-20 14:13:10 CET; 2min 55s ago
Process: 1853 ExecStart=/usr/sbin/icingadb --config /etc/icingadb/config.yml (code=exited, status=1/FAILURE)
Main PID: 1853 (code=exited, status=1/FAILURE)
CPU: 49ms
Feb 20 14:13:10 server00 systemd[1]: Starting Icinga DB...
Feb 20 14:13:10 server00 icingadb[1853]: Starting Icinga DB
Feb 20 14:13:10 server00 systemd[1]: Started Icinga DB.
Feb 20 14:13:10 server00 icingadb[1853]: Connecting to database at 'localhost:0'
Feb 20 14:13:10 server00 icingadb[1853]: Connecting to Redis at 'localhost:6380'
Feb 20 14:13:10 server00 icingadb[1853]: Starting history sync
Feb 20 14:13:10 server00 icingadb[1853]: encoding/hex: invalid byte: U+002D '-'
can't decode hex "a76a6e8b-3722-4d83-83d1-f25aa390d127"
github.com/icinga/icingadb/internal.CantDecodeHex
github.com/icinga/icingadb/internal/internal.go:10
github.com/icinga/icingadb/pkg/types.(*Binary).UnmarshalText
github.com/icinga/icingadb/pkg/types/binary.go:56
github.com/icinga/icingadb/pkg/structify.parseString
github.com/icinga/icingadb/pkg/structify/structify.go:114
github.com/icinga/icingadb/pkg/structify.structifyMapByTree
github.com/icinga/icingadb/pkg/structify/structify.go:86
github.com/icinga/icingadb/pkg/structify/structify.go:102
github.com/icinga/icingadb/pkg/structify.MakeMapStructifier.func1
github.com/icinga/icingadb/pkg/structify/structify.go:42
github.com/icinga/icingadb/pkg/icingadb/history.writeOneEntityStage.func1
Redis seems to be working properly:
systemctl status icingadb-redis
● icingadb-redis-server.service - Advanced key-value store
Loaded: loaded (/lib/systemd/system/icingadb-redis-server.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-02-20 14:13:08 CET; 13min ago
Docs: http://redis.io/documentation,
man:icingadb-redis-server(1)
Main PID: 1176 (icingadb-redis-)
Status: "Ready to accept connections"
Tasks: 5 (limit: 154187)
Memory: 17.5M
CPU: 1.808s
CGroup: /system.slice/icingadb-redis-server.service
└─1176 /usr/bin/icingadb-redis-server 127.0.0.1:6380
Feb 20 14:13:08 server00 systemd[1]: Starting Advanced key-value store...
Feb 20 14:13:08 server00 systemd[1]: Started Advanced key-value store.
systemctl status icingadb-redis-server
Active: active (running) since Mon 2023-02-20 14:13:08 CET; 14min ago
Memory: 17.6M
CPU: 1.861s
Icingadb feature is also enabled
icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb influxdb2 livestatus notification opentsdb perfdata statusdata syslog
Enabled features: api checker icingadb mainlog
Im really lost, any help would be appreciated
