Hello there.
We have a problem when we try to get information about available space using ageneric-snmp-all-partitions. We still have a Icinga 1 running which shows the correct available disk space, but Icinga 2 has on several different machines shown other numbers. The difference seems to be about 5%, whereas Icinga 2 shows that 5% more is available than what is actually available (and what Icinga 1 shows).
Here is one example from a NAS. This is what we can see in Icinga 2:
/: 52%
/dev/shm: 0%
/run: 2%
/sys/fs/cgroup: 0%
/tmp: 0%
/volume1: 86% (<90%) : OK
Name Used Max Warning Critical
/volume1 6,71 TiB 7,85 TiB 7,06 TiB 7,45 TiB
/ 1204,74 MiB 2,28 GiB 2,05 GiB 2,16 GiB
/run 38,30 MiB 1888,00 MiB 1699,00 MiB 1794,00 MiB
/tmp 1248,05 KiB 1888,00 MiB 1699,00 MiB 1794,00 MiB
/dev/shm 120,01 KiB 1888,00 MiB 1699,00 MiB 1794,00 MiB
/sys/fs/cgroup 0,00 B 1888,00 MiB 1699,00 MiB 1794,00 MiB
The command looks like this:
template Service "ageneric-snmp-all-partitions" {
import "Active_Template_Check_Ausführung"
check_command = "snmp-storage-linux"
vars.snmp_crit = "95"
vars.snmp_storage_name = "/"
vars.snmp_warn = "90"
And these are the numbers that Icinga 1 shows us and which are indeed what is actually on the machine, it does use the “check_all_partitions” command though:
WARNING: /volume1:90%
/:56%
/run:7%
/tmp:5%
/dev/shm:5%
/sys/fs/cgroup:5%
This problem also does occur on more or maybe even all servers. I checked another Linux VM which is nearly empty, and while Icinga 1 shows around 88% on one partition and 5% on all others, Icinga 2 shows 84% and 0%-1% on all others, so again around 5% discrepancy.
Now I wasn’t the one who actually worked on Icinga 2, but I am the one who now has to fix it. I see that Icinga 2 also has a “check_disk” command. I am not completely sure why one command was used instead of another or of the “check_all_partitions” simply doesn’t exist anymore. Any ideas what may cause this discrepancy?
- Director version (System - About): 1.8.0
- Icinga Web 2 version and modules (System - About): 2.10.1
- Icinga 2 version (
icinga2 --version
): r2.13.3-1) - Operating System and version: Debian 10
- Webserver, PHP versions: Apache 2: 2.4.38-3+deb10u7 & php 7.3
