Problem agent install
The components from my Agent on Windows Server 2012R2
Icinga2-v2.13.1-x86_64.msi
icinga-powershell-framework-1.6.1.zip
icinga-powershell-plugins-1.6.0.zip
icinga-service-v1.1.0.zip
I have a problem to install the agent only one Server from my 1000Servers. It looks like that.
If I click on the icinga2-v213.1-x68_64 msi I get this error
grafik
I think the old client is not complete uninstalled. This client gives the message at beginning “tha agent is not installed”. But if I try to uninstall the with a old msi, I get the message a new client is installed.
How can I delete the client complete manually. I have delete this folders:
c:\Program Files\ICINGA2
c:\Program Files\icinga-framework-service
c:\ProgramData\icinga2\
Services:
icinga2
icingapowershell
If I try to install a old version I get the message an newer Version is installed.
It looks like a problem with the trend-micro. If I deaktivate the trend micro it works. I don’t know what in this trend micro agent differet to the other trend-micro agents.
Need I exceptions in the virus scanner for the icinga agent?
Hello @el-dummy!
Yes, you do.
Best,
AK
I tried this following 3 command on powershell , and after that, the installation work. Try it
Uninstall-IcingaAgent -RemoveDataFolder
Remove-Item -ErrorAction SilentlyContinue -Path “C:\ProgramData\icinga2” –recurse -Force
Remove-Item -ErrorAction SilentlyContinue -Path “C:\Program Files\icinga-framework-service” –recurse -Force
