Hi guys,
I am trying to sync (create) services from an existing datasource in icinga director. Alle the prechecks (Check for changes) running fine but on “Trigger this Sync” I am facing the error:
Icinga\Module\Director\Objects\IcingaService uv2-rtt-check-(XXX/1.1.1.1): preg_match(): Unknown modifier ''
My environment:
Icinga Core 2.12.1-1
Director: 1.7.2 (git 9c95fb8680f6f389ca24ff6e41d9002185596cb3)
ipl: 0.5.0
reactbundle: 0.7.0
incubator: 0.5.0
PHP:
php -v
PHP 7.4.12 (cli) (built: Nov 3 2020 14:31:48) ( NTS )
sample data (anonymised) for my import / sync:
rtt_checks_uid | rtt_checks_descr | rtt_checks_ip | rtt_checks_location | rtt_checks_method | sat_descr | sat_ip | sat_rtt_satid |
19!1.2.3.4 | some office | 1.2.3.4 | XXX | vpn | AAA | 5.6.7.8 | 19 |
20!1.2.3.4 | some office | 1.2.3.4 | XXX | vpn | BBB | 9.10.11.12 | 20 |
key column -> rtt_checks_uid (concat in psql query)
The sync rule:
Source name | Source field | Destination | Prio |
uv2-db-rtt-checks | uv2-rtt-check-(${sat_descr}/${rtt_checks_ip}) | object_name | |
uv2-db-rtt-checks | director-template-service-rtt | import | |
uv2-db-rtt-checks | hostname.domain.tld | host | |
uv2-db-rtt-checks | ${rtt_checks_descr} | notes |
Is that a bug?
Thx & br
Oliver
