I’m trying to access a variable from the relevant host inside a NotificationCommand object. So like:
Object NotificationCommand "some-notification-command" {
command = [ SysconfDir + "/icinga2/scripts/some-notification-command.sh" ]
env = {
FOO = get_host("$host.name$").vars.foo
Now, I know vars.foo
is set on the host, but when this NotificationCommand fires I always get an empty value in that environment variable. Is it not possible to access host custom variables in this way?
Do I have to do it as a script argument?
Thanks!
