I’ve installed icinga2 and was setting up a systemd check for an agent.
On all hosts, I have installed the following packages:
icinga2
icinga2-common
monitoring-plugins
monitoring-plugins-systemd
The configuration in /usr/share/icinga2/include/plugins-contrib.d/systemd.conf comes from icinga2-common. My version is:
apt policy icinga2-common
icinga2-common:
Installed: 2.13.6-2+deb12u1
Candidate: 2.13.6-2+deb12u1
Version table:
*** 2.13.6-2+deb12u1 500
500 http://deb.debian.org/debian bookworm/main amd64 Packages
100 /var/lib/dpkg/status
This file references: check_systemd.py:
/* Icinga 2 | (c) 2012 Icinga GmbH | GPLv2+ */
object CheckCommand "systemd" {
command = [ PluginContribDir + "/check_systemd.py" ]
arguments = {
"--unit" = {
value = "$systemd_unit$"
description = "Name of the systemd unit that is being tested."
But the file provided by monitoring-plugins-systemd is check_systemd without .py:
$ dpkg -X monitoring-plugins-systemd_2.3.1-4_all.deb .
./usr/
./usr/lib/
./usr/lib/nagios/
./usr/lib/nagios/plugins/
./usr/lib/nagios/plugins/check_systemd
./usr/share/
./usr/share/doc/
./usr/share/doc/monitoring-plugins-systemd/
./usr/share/doc/monitoring-plugins-systemd/changelog.Debian.gz
./usr/share/doc/monitoring-plugins-systemd/copyright
./usr/share/lintian/
./usr/share/lintian/overrides/
./usr/share/lintian/overrides/monitoring-plugins-systemd
After I edited the file provided by icinga2-common (by removing the .py) and restarting icinga2 manually on my agent, the checks were fixed.
This is effectively a bug report. If there’s a better place to post this, please let me know. I could find no references online to this error:
execvpe(/usr/lib/nagios/plugins/check_systemd.py) failed: No such file or directory
rsx
(Roland Sommer)
August 12, 2024, 6:22am
3
Pretty bad idea to change files managed by the package management. In your case it’s recommended to add a new command object. Or you use the plugin for which the command is defined in icinga2-common.
lorenz
(LorenzK)
August 12, 2024, 12:20pm
4
This is a known problem . The systematic problem is, that the Icinga crew tries to provide defintions for a lot of monitoring plugins, which may or may not be available via package manager on a specific distribution or version of a distribution.
Therefore problems like this are prone to happen.
Please don’t modify the files in /usr/share/icinga2/*, this is managed by your package manger and this workaround will fall on your feet at some point.
The better solution/workaround is to create something like /etc/icinga2/zones.d/global-templates/commands/check_systemd.conf with the content:
object CheckCommand "my_systemd" {
import "systemd"
command = [ PluginDir + "/check_systemd"]
or something like that.
LorenzK:
This would normally be a good idea.
In my case I feel confident because I made the same change as what is coming down the line:
committed 08:53AM - 08 May 24 UTC
The executable name for check_systemd's dropped the `.py` suffix for
version 2.0… .3[0], released in April 2019[1]. However, the old name is
still being referenced, both in documentation as well as in the ITL's
CheckCommand's command, making it unusable.
Closes #9547.
[0]: https://github.com/Josef-Friedrich/check_systemd/compare/v2.0.2...v2.0.3#diff-60f61ab7a8d1910d86d9fda2261620314edcae5894d5aaa236b821c7256badd7
[1]: https://github.com/Josef-Friedrich/check_systemd/releases/tag/v2.0.3
Thanks.
