Hi Community,
I would like to integrate a sensor into my monitoring.
For this I took a Raspberrypi, built in icinga tools and a python file for the sensor check. So far so good. Unfortunately the service for the check on my Icinga server reports the following:
execvpe(/usr/lib/nagios/plugins/check_test.py) failed: Permission denied.
Does anyone have an idea what this could be? The check is stored on this path on my pi. #
The ssh and icinca checks I created are all ok.
Icinga2 log:
[2022-01-19 11:10:05 +0100] warning/PluginCheckTask: Check command for object ‘testpi’ (PID: 1009, arguments: ‘/usr/lib/nagios/plugins/check_test.py’ ‘-c’ ‘55’ ‘-w’ ‘40’) terminated with exit code 128, output: execvpe(/usr/lib/nagios… permission denied)>
best wishes!
