Plugin Output in XML Format
Hello All,
I’m getting plugin output in xml format and icinga doesn’t print the it in pretty way in web console. Just printing the xml itself without space.
Does anyone has a solution for this? Please advice.
Which plugin is doing this?
Antony.
Custom Plugin result is in XML format and the same is not being printed in pretty way in Icinga.
All I can suggest is “re-write the plugin so that it produces output in the
format Icinga expects”. This is a standard format used by many different
monitoring systems, to ensure inter-operability of plugins.
https://icinga.com/docs/icinga2/latest/doc/05-service-monitoring/ and
https://www.monitoring-plugins.org/doc/guidelines.html should help if you need
guidance on what the format should be.
Antony.
