I’ve setup icinga2 and tried to add an agent. I have followed the documentation, but in the icinga2 dashboard the services are all OK even if they’re NOT OK. I’ve figured out, that the dashboard the value for the agent-01 and the master are the same, for example the apt-check and free space
For example:
The Dashboard says for agent-01:
APT OK: 0 packages available for upgrade (0 critical updates).
If I run /usr/lib/nagios/plugins/check_apt -v on agent-01, it show’s:
APT CRITICAL: 30 packages available for upgrade (1 critical updates). |available_upgrades=30;;;0 critical_updates=1;;;0
DISK OK - free space: / 135973MiB (96% inode=99%);
and for icinga2.my.domain:
But executed directly on the agent-01:
DISK OK - free space: / 126471MiB (66% inode=98%);| /=65911390208B;167384606310;188307682099;0;209230757888
On the master-node (icinga2.my.domain) I did following:
icinga2 node wizard
**Welcome to the Icinga 2 Setup Wizard!**
**We will guide you through all required configuration details.**
**Please specify if this is an agent/satellite setup ('n' installs a master setup)** [Y/n]: n
**Starting the Master setup routine...**
**Please specify the common name** (CN) [icinga2.my.domain]:
**Reconfiguring Icinga...**
Checking for existing certificates for common name 'icinga2.my.domain'...
Certificate '/var/lib/icinga2/certs//icinga2.my.domain.crt' for CN 'icinga2.my.domain' already existing. Skipping certificate generation.
**Generating master configuration for Icinga 2.**
'api' feature already enabled.
Master zone name [master]: master
Do you want to specify additional global zones? [y/N]:
**Please specify the API bind host/port** (optional)**:**
**Bind Host** []:
**Bind Port** []:
Do you want to disable the inclusion of the conf.d directory [Y/n]: n
**Checking if the api-users.conf file exists...**
**Done.**
on the agent-01 I did:
icinga2 node wizard
**Please specify if this is an agent/satellite setup ('n' installs a master setup)** [Y/n]: Y
Starting the Agent/Satellite setup routine...
**Please specify the common name (CN)** [agent-01.my.domain]:
**Please specify the parent endpoint(s) (master or satellite) where this node should connect to:**
**Master/Satellite Common Name** (CN from your master/satellite node): icinga2.my.domain
Do you want to establish a connection to the parent node **from this node?** [Y/n]: Y
**Please specify the master/satellite connection information:**
**Master/Satellite endpoint host** (IP address or FQDN): icinga2.my.domain
**Master/Satellite endpoint port** [5665]: 5665
**Add more master/satellite endpoints?** [y/N]: N
**Parent certificate information:**
Version: 3
Subject: CN = icinga2.my.domain
Issuer: CN = Icinga CA
Valid From: Mar 24 12:29:30 2025 GMT
Valid Until: Apr 25 12:29:30 2026 GMT
Serial: e0:a2:f3:af:2a:ad:ce:c3:bf:38:23:ed:e2:b8:95:83:66:10:3a:82
Signature Algorithm: sha256WithRSAEncryption
Subject Alt Names: icinga2.my.domain
Fingerprint: 64 D9 12 42 A7 AD 26 1E 77 0E C6 66 79 27 CD 0C 64 0B 37 B2 A9 57 09 0E 88 57 5F 0F D3 30 30 D0
**Is this information correct?** [y/N]: Y
**Please specify the request ticket generated on your Icinga 2 master** (optional)**.**
(Hint: # icinga2 pki ticket --cn 'agent-01.my.domain'): 43d24a789b540d76077e8e7b7f9ce34c14df13db
**Bind Host** []:
**Bind Port** []:
**Accept config from parent node?** [y/N]: Y
**Accept commands from parent node?** [y/N]: Y
Disabling feature **notification**. Make sure to restart Icinga 2 for these changes to take effect.
Enabling feature **api**. Make sure to restart Icinga 2 for these changes to take effect.
Local zone name [agent-01.my.domain]:
Parent zone name [master]: master
Do you want to disable the inclusion of the conf.d directory [Y/n]: Y
**Disabling the inclusion of the conf.d directory...**
**Done.**
**Now restart your Icinga 2 daemon to finish the installation!**
All Services are restarted. I’ve tried several things know and I’m new to icinga2 and can’t figure out how to debug (chatGPT also did not help ..). I’ve tried purging the config on the agent-01 and reinstalling. Rerun the setup wizard on the node. Tried telnet 5665 (It’s working).
My Zone file looks like this:
cat /etc/icinga2/zones.conf
* Zone configuration for distributed Icinga 2 setup.
object Endpoint "icinga2.my.domain" {
host = "icinga2.my.domain"
object Zone "master" {
endpoints = [ "icinga2.my.domain" ]
object Endpoint "agent-01" {
host = "agent-01"
object Zone "agent-01" {
endpoints = [ "agent-01" ]
/* Global templates and sync for Icinga Director */
global = true
global = true
my object host looks like this
cat /etc/icinga2/conf.d/my_hosts.conf
object Host "agent-01" {
import "generic-host"
address = "build-06.apus.work"
check_command = "hostalive"
vars.os = "Linux"
vars.apt_check = true
vars.load_check = true
