Attached picture here, I would like to see the performance data in percentages. Why this is showing the values. My question does make sense?
Can someone help on this?
That’s just the current runtime state, more or less informal. If you want to modify such, change the plugin’s output if possible.
Or you’ll look into specific graph integration with better templating.
