Performance data for some services is not recorded in graphite
(please see below for environment information)
we are having the problem that for some services the performance data is not recorded in graphite (and thus no graph shown in icingaweb2, just two pie charts), but for other services it is. We cannot discern any reason for this.
Output from a service failing to record data:
    "mem_usage=73%;75;90;0",
    "cpu_load=44%;90;98;0"
Output from a service that is working fine:
    "battery=100%;;;0;100",
    "load=42%;;;0;100"
What else may be wrong? What are we missing?
Thanks for any help or pointers,
Jörg
root@monitor:/etc/icinga2# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.3-1)
System information:
  Platform: Ubuntu
  Platform version: 24.04.1 LTS (Noble Numbat)
  Kernel: Linux
  Kernel version: 6.8.0-48-generic
  Architecture: x86_64
Build information:
  Compiler: GNU 13.2.0
  OpenSSL version: OpenSSL 3.0.13 30 Jan 2024
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
root@monitor:/etc/icinga2# icinga feature list
Command 'icinga' not found, did you mean:
  command 'icinga2' from deb icinga2-bin (2.13.8-1)
Try: apt install <deb name>
root@monitor:/etc/icinga2# icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf influxdb influxdb2 journald livestatus opentsdb perfdata syslog
Enabled features: api checker graphite icingadb mainlog notification
root@monitor:/etc/icinga2# icinga2 daemon -C
[2024-11-20 14:08:23 +0100] information/cli: Icinga application loader (version: r2.14.3-1)
[2024-11-20 14:08:23 +0100] information/cli: Loading configuration file(s).
[2024-11-20 14:08:23 +0100] information/ConfigItem: Committing config item(s).
[2024-11-20 14:08:23 +0100] information/ApiListener: My API identity: monitor
[2024-11-20 14:08:23 +0100] warning/ApplyRule: Apply rule 'ping6' (in /etc/icinga2/conf.d/services.conf: 34:1-34:21) for type 'Service' does not match anywhere!
[2024-11-20 14:08:23 +0100] warning/ApplyRule: Apply rule 'check-ad-replication' (in /etc/icinga2/conf.d/services.conf: 144:1-144:36) for type 'Service' does not match anywhere!
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 2 NotificationCommands.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 114 Notifications.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 2 HostGroups.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 32 Hosts.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 Downtime.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 3 Comments.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 IcingaDB.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 3 Zones.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 User.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 Endpoint.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 262 CheckCommands.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 GraphiteWriter.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 UserGroup.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 3 ServiceGroups.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 3 TimePeriods.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2024-11-20 14:08:23 +0100] information/ConfigItem: Instantiated 91 Services.
[2024-11-20 14:08:23 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2024-11-20 14:08:23 +0100] information/cli: Finished validating the configuration file(s).
root@monitor:~# icinga2 feature list
Sorry for the noise. Turns out it was unrelated to icinga2. The carbon-cache daemon stopped running because of a system misconfiguration, so the data for the new services was never recorded.
