Perfdata error
Hello Folks,
I’m using Icinga Web 2 Version 2.8.2, icinga2-2.12.3-1 and pnp module Version 1.1.0. After upgrading to the newest version of icinga, I have noticed errors in /var/log/pnp4nagios/perfdata.log.
2021-03-23 17:16:23 [3354] [0] RRDs::update ERROR /var/lib/pnp4nagios//host0.com/proc_meminfo_InactiveFile.rrd: illegal attempt to update using time 1616516175 when last update time is 1616516175 (minimum one second step)
2021-03-23 17:16:23 [3354] [0] RRDs::update /var/lib/pnp4nagios//hostA.com/multi_A_node_In_A_node_In__check_multi__time.rrd 1616516176:1.359673
2021-03-23 17:16:23 [3354] [0] RRDs::update ERROR /var/lib/pnp4nagios//hostB.com/multi_B_node_In_B_node_In__check_multi__time.rrd: illegal attempt to update using time 1616516176 when last update time is 1616516176 (minimum one second step)
deleting /var/lib/pnp4nagios/* and restart npcd returned the error messages. Somebody have a idea how I can fix this error?
Many thanks in advance!
Best regards
David
Problem found and solved. It is the fault of a check, the check wrote twice in the same perfdata description field.
For example:
FreeMemory = xxx;;;;
Best regards
David
