We are looking into migrating from “Vanilla” Icinga2 to Director. In our Icinga2 configuration, hosts have an uplinks dictionary that does not only contain names, but also extra information about interfaces:
GigabitEthernet0 => {
counter64 => true
kbps_down => 10000.0
kbps_up => 10000.0
GigabitEthernet1 => {
counter64 => true
kbps_down => 50000.0
kbps_up => 50000.0
This is importanf for us, because hosts can have multiple uplinks with different speeds. This lets us configure snmp checks with different thresholds, and enable/disable 64bits counter per-interface.
apply Service for (iface_name => iface_details in host.vars.wans) {
vars.snmp_interface = iface_name
vars.snmp_interface_64bit = iface_details.counter64
vars.snmp_warn = 0.9*iface_details.kbps_down + "," + 0.9*iface_details.kbps_up
vars.snmp_crit = iface_details.kbps_down + "," + iface_details.kbps_up
However, Director only accepts arrays for apply rules so a direct migration is not possible… How can I make this work? I could probably workaround the 64-bit counter issue by setting it at host level, but thresholds must be per-interface. Of course there is also the option to hard code uplink1_xxx, uplink2_xxx, etc. at host level but this would defeat the purpose…
Any ideas?
