Hi Team,
We are trying to monitor the palo alto firewall bandwidth from the icinga can anyone help on this please we are using aggregated interface
Hi Team,
hi & welcome in the community
I found this centreon-plugins :: Icinga Exchange. I don’t now this script or the hardware, but maybe it works. If not and if it’s possible to access with snmp, you can try check_snmp. With this check you have to know the OIDs
Thank you for your reference I will check centreon-plugins :: Icinga Exchange. and get back to you with the result.
