Output Unavailable from Icinga Agents
I am pretty new to Icinga2. I need to setup a icinga2 monitoring system. I already tested it in my Lab. Here it is working when I assign a service to a host and I get output from that service e.g check load. But now I installed it in the prod environment and the Output is not working. It is a Director setup with the Kickstart Agent installation.
I already checked port 5665 and it´s open.
Here are some information regarding the Icinga2 Installation.
Icinga2 Version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 22.04.3 LTS (Jammy Jellyfish)
Kernel: Linux
Kernel version: 5.15.0-92-generic
Architecture: x86_64
Build information:
Compiler: GNU 11.4.0
OpenSSL version: OpenSSL 3.0.2 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Enabled Features
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb influxdb2 journald livestatus opentsdb perfdata syslog
Enabled features: api checker icingadb mainlog notification
icinga2 daemon -C
[2024-02-05 16:45:02 +0000] information/cli: Icinga application loader (version: r2.14.2-1)
[2024-02-05 16:45:02 +0000] information/cli: Loading configuration file(s).
[2024-02-05 16:45:02 +0000] information/ConfigItem: Committing config item(s).
[2024-02-05 16:45:02 +0000] information/ApiListener: My API identity: rdcp-monitor01
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 2 NotificationCommands.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 13 Notifications.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 6 HostGroups.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 3 Hosts.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 Downtime.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 IcingaDB.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 FileLogger.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 5 Zones.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 User.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 3 Endpoints.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 ApiUser.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 ApiListener.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 NotificationComponent.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 246 CheckCommands.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 UserGroup.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 3 ServiceGroups.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 3 TimePeriods.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2024-02-05 16:45:02 +0000] information/ConfigItem: Instantiated 18 Services.
[2024-02-05 16:45:02 +0000] information/ScriptGlobal: Dumping variables to file ‘/var/cache/icinga2/icinga2.vars’
[2024-02-05 16:45:02 +0000] information/cli: Finished validating the configuration file(s).
Here is the Icinga2 conf file:
  • Icinga 2 configuration file
    • this is where you define settings for the Icinga application including
  • which hosts/services to check.
  • For an overview of all available configuration options please refer
  • to the documentation that is distributed as part of Icinga 2.
  • The constants.conf defines global constants.
    include “constants.conf”
  • The zones.conf defines zones for a cluster setup.
  • Not required for single instance setups.
    include “zones.conf”
  • The Icinga Template Library (ITL) provides a number of useful templates
  • and command definitions.
  • Common monitoring plugin command definitions are included separately.
    include
    include
    include
    include
  • This includes the Icinga 2 Windows plugins. These command definitions
  • are required on a master node when a client is used as command endpoint.
    include
  • This includes the NSClient++ check commands. These command definitions
    include
  • The features-available directory contains a number of configuration
  • files for features which can be enabled and disabled using the
  • icinga2 feature enable / icinga2 feature disable CLI commands.
  • These commands work by creating and removing symbolic links in
  • the features-enabled directory.
    include "features-enabled/
    .conf"
  • Although in theory you could define all your objects in this file
  • the preferred way is to create separate directories and files in the conf.d
  • directory. Each of these files must have the file extension “.conf”.
    include_recursive “conf.d”
Attached is the system - about page
Thank you very much in advance.
Best regards,
Benedikt
Hi Benedikt,
your first screenshot shows the service state as “pending”, so it has not been executed yet, so there is no output to display. Try to find out, why it is not executed.
Regards,
Dirk
