I have a bunch of CentOS 7 host that will be migrated to Oracle Linux 9. I do not see the RPMs for Oracle Linux 9 or CentOS 9 here: https://packages.icinga.com/
Should I be investigating how to build Icinga from source?
I guess you need to compile them yourself or get a subscription for access to the RHEL 9 packages that are stated as compatible.
Can you point me to some documentation on how to compile them?
I think I found the instructions here: Development - Icinga 2
