Has anyone done OpsGenie Integration using Director?
yes, it is very straight forward.
there is a integration written in go Icinga2 Integration
here are some command line arguments:
https://github.com/opsgenie/opsgenie-integration/blob/master/icinga2/icinga2/opsgenie.conf
Thanks. I found some reference here which helped - NetEye Incident Response with Atlassian Opsgenie Integration | www.neteye-blog.com
Has anyone implemented alert “priority” in Icinga2 to work with Opsgenie?
