OpenTelemetry Integration
Is there a plan to integrate Opentelemetry with ICINGA2?
I search on the forum but there i not so much.
I wondering is DEV TTEAM is thinking about it.
And: Does this integration make sense ?
REgards
P.
Opentelemetry and icinga are based on totally different approaches. I’d like to know what you wanna achieve? Could you share your ideas?
