I would like to ask if someone already monitors components like Exchange/Sharepoint/Onedrive/Teams etc. from Office 365 with Icinga2.
How is the experience?
What checks/modules are used?
Best Regards,
Rafael
Best Regards,
Rafael
Due to today’s failures, I’m also looking for a way to monitor O365 services. Have you found a way by now? Theoretically, it should be possible to get the information you need through the Office 365 Administration APIs.
Frank.
Yes, i think thats the best way. Alternativly you can go with PS remote session. Etherway, would if someone already have some useful ideas.
What was your problem?
