I have a slight misconnfiguration on my system which I hope to fix with your help Thing is, my icinga2, icingaweb2 and icinga director do work as intended.
What doesn’t work is the icingacli as ist apparently has problems to use the database configured in the resources.ini:
root@icinga-master-01:/usr/share/icingaweb2# icingacli director health
Icinga Director: there are problems
Director configuration: 0 tests OK, 1x CRITICAL
[CRITICAL] No database resource has been specified
root@icinga-master-01:~# mv /etc/icingaweb2 /etc/icingaweb2.save
root@icinga-master-01:~# ln -s /usr/share/icingaweb2 /etc/icingaweb2
root@icinga-master-01:~# icingacli director health
Icinga Director: everything is fine
Director configuration: 3 tests OK
[OK] Database resource 'director_db' has been specified
[OK] Make sure the DB schema exists
[OK] There are no pending schema migrations
Director Deployments: 3 tests OK
[OK] Deployment endpoint is 'icinga-master-01'
[OK] There are 0 un-deployed changes
[OK] The last Deployment was successful 50m 15s ago
Import Sources: 1 tests OK
[OK] 'Host From CSV' is in sync
Sync Rules: 1 tests OK
[OK] 'Import Host' is in sync
Director Jobs: 1 tests OK
[OK] No Jobs have been defined
we’ll see. So far things look quite good to me and everything I need is working fine. I don’t doubt, that this smells heavily like a “quick’n dirty” kind of a fix. Given this solution my assumption is I would have to redeploy my whole system and do a clean install from scratch which simply isn’t an option right now.
You need to read the docs, there are all steps in you need to do. But to help you we need more information like which OS, how did you install (from Icinga Repositories?) and if the icinga user was added to the icingaweb group. Looks like icingacli could not read the needed information.
Here is how my directories look like (CentOS7 installed from Icinga repo)
[root@master-icinga-p1 ~]# ls -la /etc/icingaweb2/
total 48
drwxrws---. 5 root icingaweb2 4096 Jul 30 13:48 .
drwxr-xr-x. 97 root root 12288 Aug 8 10:27 ..
-rw-rw---- 1 apache icingaweb2 188 May 22 15:44 authentication.ini
-rw-rw---- 1 apache icingaweb2 343 Jul 29 10:59 config.ini
drwxrws--- 3 apache icingaweb2 4096 Jun 28 12:02 dashboards
drwxrws---. 2 root icingaweb2 4096 Aug 2 11:29 enabledModules
-rw-rw---- 1 apache icingaweb2 206 May 22 15:45 groups.ini
drwxrws---. 11 root icingaweb2 4096 Aug 2 11:03 modules
-rw-rw---- 1 apache icingaweb2 1134 May 22 16:28 resources.ini
-rw-rw---- 1 apache icingaweb2 139 Jun 13 14:55 roles.ini
[root@master-icinga-p1 ~]# ls -la /usr/share/icingaweb2/
total 28
drwxr-xr-x. 7 root root 4096 Jul 30 13:48 .
drwxr-xr-x. 114 root root 4096 Jul 9 08:33 ..
drwxr-xr-x. 9 root root 4096 Aug 2 08:05 application
drwxr-xr-x. 4 root root 4096 Aug 2 08:05 doc
drwxr-xr-x. 3 root root 4096 Jul 30 13:48 library
drwxr-xr-x. 22 root root 4096 Aug 2 11:29 modules
drwxr-xr-x. 6 root root 4096 Aug 2 08:05 public
Thanks - conceirneing the security aspect is right but be sure that this machines are very well firewalled inside the internal network, as well as they don’t have a direct connection to the internet, besides several other security-settings…here you go for the information requested:
root@icinga-master-01:~# ls -la $(which icingacli) ; icingacli version ; uname -a ; php -version
-rwxr-xr-x 1 root icingaweb2 218 Jul 30 10:49 /usr/bin/icingacli
Icinga Web 2 2.7.0
Git Commit 861c5601b6e01402a932687d7b59a037c72a6804
PHP Version 7.0.33-0+deb9u3
MODULE VERSION
businessprocess 2.2.0
cube 1.1.0
director 1.6.2
doc 2.7.0
fileshipper 1.1.0
grafana 1.3.5
ipl v0.3.0
map 1.1.0
monitoring 2.7.0
Linux icinga-master-01 4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u4 (2019-07-19) x86_64 GNU/Linux
PHP 7.0.33-0+deb9u3 (cli) (built: Mar 8 2019 10:01:24) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.33-0+deb9u3, Copyright (c) 1999-2017, by Zend Technologies
