I’m wanting to check uptime using nscp-local-uptime for machines that are in need of a reboot for updates. e.g. if a server has been up for over 90 days, we want to issue a warning, above 180 days we want to issue a critical.
The filter works when specifying one entry under Nscp Arguments e.g. critical=uptime > 180.0d however if we try to specify the two values e.g. critical=uptime > 180.0d warning=uptime > 90.0d we instantly get “Failed to validate filter see log for details: Critical expression is not valid”.
Messed around with quotes and all sorts but can’t get it to process?
