I am facing weird problems at the moment when trying to monitor services on windows machines using the Icinga2Agent and the nscp++ client coming with it.
The configuration for these machines is equal on the master node’s side since we create the host entries automized, and the configuration should be equal on the agents’ sides since we only go through the documented IcingaAgent installation process for windows machines. Yet the same checks applied to different agents return working results form some, but the error message
command name unknown command(s): command name
Did I miss to install some needed check-libraries when installing the nscp client? Did nscp mess up in any way? I don’t really know where to start looking for irregularities since there basically should never be any the way we set up things.
Best
Daniel
