Thank you for the reply. I did see that discussion however everything works just fine when I run and RPE directly and I’m also able to run it against the remote host without issue. Once I move away from the command line and try to see the checks in the web client that is when I notice it is failing.
Okay, i see. You may either check the debug log (icinga2 feature enable debuglog) or query the API for the full command that is executed by icinga. Maybe this will show you what arguments are missing.
